e46 B3s - Amber Oil Light
bmw virgin
Post by bmw virgin » Sun Oct 23, 2016 10:48 pm
Hi Guys
Any ideas why the oil light comes on amber for about 10secs within a minute of starting up? It doesn't matter if the engine is hot or cold, it still comes on!
Colin
2004 Titanium Silver E46 Alpina B3s Coupe #090 - Sold
Post by hap » Sun Oct 23, 2016 11:12 pm
Faulty sensor or due a top up as gone below min level
If haven't checked for while then cud b low
Post by Charles » Mon Oct 24, 2016 4:05 pm
As Hap has said ...
The engine oil sensor goes through a test cycle after start-up and if it goes out but then reappears about 30 seconds later then this suggests a faulty sensor - but in my case, it glowed red not amber.
That being the case, it is more likely to be a true warning about low oil level - but then again, you should get the amber light coming on when you switch off.
scalesg
Post by scalesg » Mon Oct 24, 2016 7:43 pm
Edit - Sorry, I misread as you say after start up
Info below is correct anyhow but doesn't help you
Amber oil light after engine switch off = check your oil level - This is straight from the BMW owners manual
I know as I had a leaky 330 as my last car :-)
Red oil light whilst driving = Stop immediately and check oil level
E46 B3S Saloon
E46 330Ci
Ford Orion 1.6i Ghia
Fiat 131 Supermiafiori
Post by Charles » Mon Oct 24, 2016 11:32 pm
Before any of this, we need to know what the actual oil level is ...
bmw virgin
Post by bmw virgin » Sun Nov 20, 2016 12:36 am
The oil was a little low but I topped it up and covered 150mls shortly after. The oil light still behaves the same! :shock:
Colin
Post by Charles » Sun Nov 20, 2016 2:17 pm
bmw virgin wrote:The oil was a little low but I topped it up and covered 150mls shortly after. The oil light still behaves the same! :shock:
Then I believe that you have a faulty oil level sensor
Post by hap » Wed Jan 18, 2017 11:02 pm
My light was acting strange topped up 500ml few days ago
Then today every time I start car does the correct sequence of red Amber goes off however it comes on while driving stays on for 10 secs and goes off and doesn't then reappear
Will check level when cold?
Normally light would come on after turning off of it's low on oil
bmw virgin
Post by bmw virgin » Wed Jan 18, 2017 11:07 pm
That's exactly how the oil light behaves on my car. Doesn't matter whether the oil is topped up or not. Will be interesting to see what causes it! :D
Colin
Post by hap » Wed Jan 18, 2017 11:16 pm
Right Colin how long has yours done it? Presume your level is ok
It does feel like sensor has given up the ghost ?
Cheer
bmw virgin
Post by bmw virgin » Wed Jan 18, 2017 11:37 pm
Been doing it at least 3 months. Happens every time I start up, whether the engine is hot or cold. I don't think the amount of engine revs affects it either.
I'm no expert but it does make you think it could be a sensor issue.
Colin
Post by hap » Thu Jan 19, 2017 12:16 am
Have You costed a replacement at all ?
Bertroex
Post by Bertroex » Thu Jan 19, 2017 12:21 am
When I had my E46, it was about 28 quid IIRC...
Kind regards,
Bert
1976 Porsche 911 Carrera 3.o
1985 Porsche 924 S
ex:1983 E28 525I, 1985 E28 528I, 1989 E30 325I Mtec coupe, 1986 M535I, 1990 E30 320i Touring, 1990 E30 325I touring, 1990 E34 525I, 1998 Z3 1.9, 1998 E39 523I SE, 1999 e46 328CI, 2008 E92 Alpina B3 BiTurbo 053
and 13 Porsches...
Post by Charles » Thu Jan 19, 2017 12:42 am
bmw virgin wrote:Been doing it at least 3 months. Happens every time I start up, whether the engine is hot or cold. I don't think the amount of engine revs affects it either.
As I said before, this is an indication that the sensor has failed.
Been there, seen it and replaced the faulty part!
Post by hap » Thu Jan 19, 2017 7:11 pm
Is it a quick fix Charles and how much
Mine still doing it ahhhh
