1 series O2 sensor query
Goto page 1, 2  Next
Post new topic   Reply to topic    theALPINAregister.com Forum Index -> My Car
PostPosted: Fri Aug 14, 2015 2:52 pm    Post subject: 1 series O2 sensor query Reply with quote
Rough starting in morning intermittent no fault codes except O2 sensor my mech thinks this wouldn't cause rough starts
No other codes of timing etc
Will be 200 to change n no guarantee it will solve it
Any advice please
[/code]
PostPosted: Sun Aug 16, 2015 10:00 am    Post subject: Reply with quote
Anyone please??
Rough again this am 11 degrees shaking and misfire.had to turn off n back on to get it going
Don't want to spend changing O2 if it won't solve it
Bat
PostPosted: Sun Aug 16, 2015 10:12 am    Post subject: Reply with quote
On older models it made no difference to cold running as the sensor had to warm up first.
I've got no experience of the 1 series though..
Have you got access to diagnostic gear to check live data from cold start up?
Cheers,
Gavin Smile
PostPosted: Sun Aug 16, 2015 10:45 am    Post subject: Reply with quote
Thanks Gavin I don't but it's had only O2 sensor going bad or something like that it's 2004 car they cleared it and came back with O2 nothing about coils or misfire codes but as it gets colder it will struggle massively as we ain't even in winter and frosty mornings
John_C
PostPosted: Sun Aug 16, 2015 1:49 pm    Post subject: Reply with quote
I think you've got to start there really, I had a bit of a google which suggests a bad pre-cat O2 sensor can give the symptoms you're experiencing but nothing concrete.
If that's the only fault code you're seeing I can only suggest fixing it and then going from there. Either way if it's throwing a code on the sensor then it needs replacing. Sad
2010 D3 BT #97 - Sold
1998 B10 V8 #71 - Sold
PostPosted: Sun Aug 16, 2015 2:15 pm    Post subject: Reply with quote
Thanks I just have a feeling I'll do it and the cold starts will still be an issue but guess may need to do it to rule it in or out
Thanks all
Normal day to day is fine only on damp coldish mornings but it's never had a warning light either which doesn't help diagnostics
Bat
PostPosted: Mon Aug 17, 2015 10:20 pm    Post subject: Reply with quote
Not all fault codes will put the light on. Might be worth getting the codes read again...
Cheers,
Gavin:)
PostPosted: Mon Aug 17, 2015 10:24 pm    Post subject: Reply with quote
Funny thing it was coldish with dew on the car and guess what......no shakes nothing at all!!
So as you can seeu dilemma in spending cash when it may not be that
Fed up😢
John_C
PostPosted: Tue Aug 18, 2015 11:35 am    Post subject: Reply with quote
Been thinking about this, and it depends on what the O2 sensor code is. Sounds almost like an intermittent air leak, that could throw the O2 sensor reading out. What's the exact fault code? The O2 sensor might not actually be failing, might just be reading outside of the range.
If the pre-cat and post-cat O2 sensors are the same part then swapping them might be the way to go - if the fault doesn't follow the sensor then it's not a sensor issue.
drewjak
PostPosted: Tue Aug 18, 2015 7:00 pm    Post subject: Reply with quote
I would also agree that an air leak seems the likely culprit
ESTORIL BLUE B3 3.3 COUPE #60 of 90
& the last 1 registered in 2000
The lack of L.S.D keeps me on the straight and narrow
ALPINA......Because Gentlemen don't drift
PostPosted: Tue Aug 18, 2015 8:39 pm    Post subject: Reply with quote
O2 sensor aging or summit like that
Where would air leak likely to be ?
Thanks chaps
MCB
PostPosted: Tue Aug 18, 2015 9:24 pm    Post subject: Reply with quote
You can try spraying "Easy Start" on your pipes and around your gaskets. As soon as you notice a rise in engine revs you have found the air leak Very Happy
1998 E36 1.8 Touring
1989 E30 M3.
2004 E60 530D
2002 E39 M5 (Sold)
Bat
PostPosted: Wed Aug 19, 2015 7:52 am    Post subject: Reply with quote
Looking at your post again you say it was missing, then you switched it off and restarted it.
Did it run cleanly from the moment you restated it?
Cheers,
Gavin Smile
PostPosted: Wed Aug 19, 2015 3:54 pm    Post subject: Reply with quote
Yes it did Gavin
Today started fine no issues!!
PostPosted: Sat Sep 12, 2015 6:17 pm    Post subject: Reply with quote
More updates
Few cold start probs dying revving nothing happening but partner said at junction stopped and went to go and car had cut out no lights on dash
Today the yellow engine light came on and she has told me leaving work the light has stayed on
Could it still be O2 sensor
Post new topic   Reply to topic    theALPINAregister.com Forum Index -> My Car All times are GMT + 2 Hours
Goto page 1, 2  Next
Page 1 of 2
