One skim too many!
Goto page 1, 2, 3  Next
Post new topic   Reply to topic    theALPINAregister.com Forum Index -> Charles's Blog
PostPosted: Tue Jun 23, 2015 12:12 am    Post subject: One skim too many! Reply with quote
Looks like I've found the limit for how many head gasket changes the 3.4 engine can take Shocked
In recent weeks I've noticed some curious behaviour with the coolant system which culminated in the car starting to overheat. After initial false hope that this was due to a faulty thermostat, it appears that I have got exhaust gases in the coolant, suggesting either a problem with the gasket or the head.
Inspection by camera reveals that coolant is seeping into cylinder 6 past the gasket which in turn suggests that the head has warped - which is a bit of a shame Rolling Eyes
Further investigations are planned to identify exactly what the problem is but I fear that I need a replacement head. Now this isn't quite as bad as it sounds as this can be achieved by taking a standard 328i head and porting the inlets to match the ALPINA spec - unless we can find an OEM replacement from a breaker.
More news to follow ...
Hodge
PostPosted: Tue Jun 23, 2015 7:19 am    Post subject: Reply with quote
That's unfortunate news Charles, but glad you can see the light that should be at the end of the tunnel, that rolling test bed you are running is certainly showing results Embarassed good luck and look forward to the results.
Mark Hodge
E46 B3s Coupe #19 (sold)
E46 B3s Touring #29 (sold)
Daily -
Range Rover Sport P400 Hybrid (For carrying dogs)
VW R32 MkIV (weekends)
PostPosted: Tue Jun 23, 2015 9:21 am    Post subject: Reply with quote
Thanks Mark Very Happy
I'm thinking about applying for some crowdfunding, mind you Shocked
John_C
PostPosted: Tue Jun 23, 2015 9:47 am    Post subject: Reply with quote
Sorry to hear that Charles, hope it's not too expensive a fix.
2010 D3 BT #97 - Sold
1998 B10 V8 #71 - Sold
dodgyken
PostPosted: Tue Jun 23, 2015 10:01 am    Post subject: Reply with quote
Ran a check here and there aren't any Alpina heads or 328 heads at the "main" dismantlers.
Have you tried the likes of Quarry etc?
PostPosted: Tue Jun 23, 2015 6:29 pm    Post subject: Reply with quote
Thanks for looking for me, Ken - much appreciated Very Happy
Haven't spoken to Quarry yet - I'm leaving all of that to Phil who is likely to have a much wider range of possible sources - but thanks for the suggestion.
I am followingh another possible avenue but we'll have to wait and see what that brings.
PostPosted: Tue Jun 23, 2015 9:17 pm    Post subject: Reply with quote
A very common head as we know. I had to do the exact same thing on my e36. I used a head of my dads old 323 which he'd had since the was about 18 months old. The engine was a nikasil failure
Anyhow i had the port work done and its all been fine for about the 45k i've put on it since
I know a very good guy for head work Charles who works out of Janspeeds workshops down in salisbury if you get stuck there.
He did my E30 head for me a few months back
PostPosted: Tue Jun 23, 2015 9:59 pm    Post subject: Reply with quote
Useful to know, Simon, and thank you.
I believe that Phil "knows a man" and has been down this route before for other customers.
We are still investigating options and costs so I may come back to you on this.
C
dodgyken
PostPosted: Wed Jun 24, 2015 7:38 am    Post subject: Reply with quote
Does the S50B30 head fit?
PostPosted: Wed Jun 24, 2015 3:51 pm    Post subject: Reply with quote
I have no idea ...
PostPosted: Sat Jul 11, 2015 1:24 pm    Post subject: Reply with quote
Fingers crossed but there should be a replacement head arriving for #049 early next week Very Happy
rc944
PostPosted: Sat Jul 11, 2015 1:35 pm    Post subject: Reply with quote
Charles glad there is light at the end of the tunnel!
was the last hg the cometic one or something else? did you end up using some different bolts in the end as well?
Alpina E46 B3s Coupe
E39 525i Sport Touring (again)
Ducati 748R
E39 525i Sport Touring (sold)
E46 330i Sport Touring (sold)
Porsche 964, 968 CS, 944 S2 (sold)
VW Mk4 R32 (sold)
PostPosted: Sat Jul 11, 2015 1:50 pm    Post subject: Reply with quote
The last one @242k miles was the oversized Cometic gasket with a stud fixing system.
Assuming all the studs are still done up to the correct torque - which I assume they are as the leakage was from the coolant channel into cylinder 6 and nothing around the outside - then we will probably stick with the studs and check what the state of the HG is. However, it is slightly thicker than standard to take into account the loss of thickness from all the previous skims, so I'll be going back to an OEM HG with the new head and keep the Cometic one for the future.
PostPosted: Mon Jul 20, 2015 6:18 pm    Post subject: Reply with quote
Freshly minted head and OEM gasket going on this week Very Happy
And whilst we have the inlet manifold removed, I am replacing the vacuum pump which needs doing and also changing the auxiliary air pump which was beginning to sound like a 747 on take-off Shocked
The final act will be to repalce the headlamp covers which, although polished recently to remove a lot of the external pitting, were rather fogged on the insde too.
Bit of a bill, I know, but worth every penny in my book Very Happy
PostPosted: Fri Jul 31, 2015 2:28 pm    Post subject: Reply with quote
She's running again yahoo
Post new topic   Reply to topic    theALPINAregister.com Forum Index -> Charles's Blog All times are GMT + 2 Hours
Page 1 of 3
