B3 Bi-Turbo vs. B3 S Bi-Turbo Power and Torque graphs
Yes, precisely where the B3 was a bit disappointing. It should be close to perfect now. Hopefully it comes with the right sound.def90cars wrote:All the extra oomph is "at the top end" then.
B3 GT3 (2014) sold 2016
B7 Turbo (1988), sold 2016
B3S biturbo E93 (2010)
B3S E46 coupe (2002) , sold 2008
B10 Bi turbo (1991), sold 2012
B7 turbo E24 (1981) sold 2014 -re bought 2016 !
- Richy_Boy
- Contact:
Removed.. my figures were rubbish
Rich
Rich
Richy_Boy
Current Car: BMW e46 M3 CS SMG
Previous:
BMW 335d M Sport Coupe Highline
BMW 123d M Sport Coupe, no DPF, 275bhp and 520nm of torques.
Historical Alpina B3S Coupe #19 Owner
Previous:
Richy_Boy wrote:Taken a quick look online for how a remapped 335i/d compares to the B3 and S BT models.
Standard 335i remapped - £400
BHP = 348 bhp
Torque = 489
Standard 335d remapped - £599
BHP = 350 bhp
Torque = 730 ftlb
Alpina B3 BT
BHP = 360 bhp
Torque = 500 ftlb this is NM so 368 Lbft
Alpina B3S BT
BHP = 400 bhp
Torque = 540 ftlb This
The B3S BT must be a proper rapid car
Rich
It will be a fast car but your FtLb are actually NM
A friend on E90 post, has 335i coupe remapped by evolve, and his car produces a dyno certified 396BHP and 430 LBFT which is 583nm but it isnt as thoroughly engineered as the ALPINA conversion.
RS4 Saloon 2007 Daytona Grey
M6 Coupe Indianapolis Red
ML420CDI Sport
ML420CDI Sport
Out of curiosity does anybody know definitively, or seen a good article describing, what the engine differences are between the B3S Bi-Turbo and the B3 Bi-Turbo?
Having compared the online specifications of the B3S Bi-Turbo against an old brochure I have for the B3 Bi-Turbo, it would appear that the compression ratios are the same and the only differences I have seen mentioned on some websites are 1.2bar instead of 1.1bar and potentially a different exhaust?
No prizes for guessing what I am thinking
- Richy_Boy
- Contact:
From a man that probably sits in his car once a week right now, you have too much time in hotel rooms thinking about such things. Your car is plenty quick enough, but yes, a remap will easily see you hitting B3S BT figures assuming your turbos are man-enough.
Considering my old Nissan was hitting 1.2bar on a bog standard T28, I'd of thought it would be fine! ..and that has 300bhp and 310ftlb from a 2.0 engine!
Rich
Rich
Richy_Boy
Previous:
Previous:
This is what Alpina told me (maybe not complete)Aiders wrote:Out of curiosity does anybody know definitively, or seen a good article describing, what the engine differences are between the B3S Bi-Turbo and the B3 Bi-Turbo?
Engine management Siemens MSD 81 allowing 1,2 bar (instead of MSD80)
Air flow intake different from BMW one (see "Alpina" logo on airbox), creating "vortex" effect (air acceleration)
Exhaust modified for less back pressure
Bigger oil cooler, placed on the left of the engine bay
Additional water cooler (inexistant on host BMW) placed on the right
New front spoiler directing air flow on these 2 radiators
Gearbox ZF 6HP19 TU modified (with different flywheel, specific management and extra planetary to allow quicker shifts), instead of 6HP19
Tyres 245 front /265 rear (instead of 225 /255)
Emission classification Euro 5 (Euro 4) .
Engine bloc, crank and pistons: unchanged from B3
Gearbox ratios : unchanged from B3
- Richy_Boy
- Contact:
All B3/D3 BTs have the 6HP19TU gearbox I believe..
Interesting they have gone to all the trouble to up the cooling, but hey, I guess they need to provide a warranty on the car no matter how it's driven.
335i's are remapped to something like 13.5psi (8.8 as standard), where as the B3S is 17.5!
Even stranger then how a Dinan remap @13.2psi produces 384bhp (5700rpm) and 421 lb-ft (570nm) on its own?!
Rich
Rich
Richy_Boy
Previous:
Previous:
Correct for 2009. My B3 catalog for comparison was of 2007..Richy_Boy wrote:All B3/D3 BTs have the 6HP19TU gearbox I believe..
Rich
The compression ratio on the 335i is 10,2. On the B3, it's 9,4, thanks to the modified (Mahle) pistons. Lower ratio allows higher boost pressure.Richy_Boy wrote: 335i's are remapped to something like 13.5psi (8.8 as standard), where as the B3S is 17.5!
Rich
A "simple" remap does not change the compression ratio as "hardware" mod is needed .
