E46 B3 3.3 Top End rebuild
rattusM3
Re: E46 B3 3.3 Top End rebuild
Post by rattusM3 » Sun Apr 10, 2022 11:30 am
How have you identified that you are getting water/coolant into cylinder 5?
Parked the car up over night after being used, next morning removed all the spark plugs and placed some old blankets around the engine bay and front wings. I then got someone to start the engine whilst I observed .... which resulted in water being pushed out of the spark plug holder of cylinder number 5 only.
Once no more water was being ejected, sprayed some WD40 into the cylinders, put plugs back and started engine which of course ran much better much quicker on cold as I guess no more water in the cylinder being pushed out to through the manifold.
To be honest I am only going to know for sure once it is all apart and I will get the head pressure tested beforehand.
Kev
2002 Alpina B3 3.3 #220
2006 E46 M3
1992 E30 M3 (sold - what a twat)
1986 E24 M6 (working on)
Ford Grand C-Max Family Wagon
And lots of other BMWs from the past
Post by simon13 » Sun Apr 10, 2022 8:12 pm
My old E36 B3 3.2 had a cracked head on cylinder no.5 around the valve throat on the inlet side. The head had been welded and failed so i replaced the head
Sounds like head will need to come off, see if its the head gasket failed and get the head pressure tested while you are there
