My G31 B5 Touring has arrived....NOW WITH A FEW PICS!
Re: My G31 B5 Touring has arrived....
Post by Metrics » Thu Nov 12, 2020 1:58 pm
Excellent news!
One final rambling on tyre pressures - I run mine on the high value as last winter both my front tyres were damaged by potholes causing sidewall damage and requiring replacement. Local councils of course showed me 2 fingers.
Going lower pressure could increase the risk of damage on our poor roads...
I find comfort plus nicely compliant, even with the full tyre pressure
Lizard Lounger
Post by Lizard Lounger » Thu Nov 12, 2020 2:10 pm
Excellent news!
Good advice, thank you for that. I hadn’t considered that side of things, just perhaps increased wear and poorer fuel economy (?) with the lower pressures. Thankfully, where I live the pot holes are few and far between. When I visit family, however, in the south east I will keep the pressures higher as the roads where they live are atrocious!
Jason
2020 G31 B5 Biturbo Touring #525 - Alpina blue
ScooBeeFive
Post by ScooBeeFive » Thu Nov 12, 2020 4:28 pm
Lizard Lounger wrote:
Thu Nov 12, 2020 1:46 pm
Well, to wrap this one up, and to hopefully move on to something more exciting than tyre pressures, I sent an email to ALPINA and they responded within the hour, confirming that my tyre pressures can be reduced to 2.7 bar at speeds below 155mph. Thank you all for your input and advice, much appreciated. :D
That's a real result - well done. Was worth asking the question and confirmed what we had been thinking.
Whilst the springs/dampers were still nice and compliant with the higher pressure, I just felt it bought a slight harshness to the ride and a hard edged response over bumps. For me, it spoilt that amazing ride/handling balance that Alpina's possess.
Guy
Post by Guy » Thu Nov 12, 2020 4:37 pm
Excellent news!
Does higher pressure result in less risk of sidewall damage risk though? The counter argument would be that the lower pressure gives more sidewall flex which means they can better absorb impacts.
Lizard Lounger
Post by Lizard Lounger » Thu Nov 12, 2020 5:18 pm
Ok....just when I thought it was sorted I received this email from ALPINA...
Dear Jason,
I made a mistake in my email. Please apologise.
I was writing about the LCI (cars built from 07/20). Your car is a B5 pre-LCI.
ALPINA tested the so called "comfort tyre pressure" only for the LCI models. Pre-LCI weren't officially tested and approved for the reduced tyre pressure. This means, that for your car, there is actually no approval for the 2.7 bar tyre pressure.
Please apologise for my mistake, we have also sold a LCI Touring in UK and the car has the number #625 which I thought was your car.
So...I wonder (and have asked) what the difference is between LCI and pre-LCI cars which makes it inadvisable to reduce the tyre pressures...? Presumably nothing, and it’s simply because the pre-LCI B5 was not tested.
Jason
Guy
Post by Guy » Thu Nov 12, 2020 5:27 pm
There's no difference in the tyre specs or the vehicle weight for the LCI, so they should be identical in terms of effect. i.e. running lower pressure will be fine.
They are just covering themselves in saying it has not been 'officially tested', thats very German (and I speak having done much business in Germany where rules and interpretations are very rigid).
Post by Charles » Thu Nov 12, 2020 6:20 pm
That would be my take on this too
My advice would be to adjust them down to, say, 3.0 bar to see how that feels and then tweak accordingly, but not go below 2.7 bar
Post by Metrics » Thu Nov 12, 2020 6:49 pm
Excellent news!
I guess that's up for debate. My tyres were damaged by potholes while at the recommended (high pressure) with sidewall damage. If the tyre had lower pressure I'd argue the flex would be so great that it would damage the rim and badly damage the tyre.
The higher pressure still allows sidewall flex afterall, but not too much flex, so what would less pressure result in?
Lizard Lounger
Post by Lizard Lounger » Thu Nov 12, 2020 7:19 pm
I took them down to 2.7 (prior to receiving the second email) and the difference is night and day. Fantastic ride comfort.
Plus, I just received a phone call (!) from ALPINA basically confirming that whilst the official line is that they haven’t tested the pre-LCI at 2.7 bar or given fuel
consumption figures at this tyre pressure, it will be fine to drive at this pressure below 155mph. Furthermore, there is no fuel consumption penalty or increase in tyre wear. In fact, the tyres will wear more on the inside at 3.4 bar because there is less surface area in contact with the road. At 2.7 bar the tyres are flat on the road and they therefore wear evenly. But I’m sure you guys know all this stuff. I’m still getting over the difference in ride quality. Result!
Jason
Guy
Post by Guy » Thu Nov 12, 2020 8:05 pm
Glad you got there in the end and pleased it has got you the result you wanted - the only reason I was so insistent is that I’ve been through it myself so knew it would sort your problem.
Lizard Lounger
Post by Lizard Lounger » Thu Nov 12, 2020 8:33 pm
Yes, and thank you for your advice, I didn’t doubt it. I just wanted to hear it from the horse’s mouth to feel comfortable with changing the pressures that much.
Jason
D3orbust
Post by D3orbust » Fri Nov 13, 2020 4:22 pm
Still waiting for those photos
:D
D5 number 21
Frosty
Post by Frosty » Sat Nov 14, 2020 3:02 pm
:D
Indeed, dirty or not would be good to see some more pictures?
D5 F11 Touring #107
churchie386
Post by churchie386 » Sat Nov 14, 2020 4:35 pm
:D
Filthier the better :D
Present & Past: Alpina D3BT (F31); Alpina D3 S (G21); Subaru Forester XT (SG 2.0); Porsche 718 Cayman; Golf R (Mk7); 911 (997.2); 911 (996); Subaru WRX STI (Hatch); Alpina D3BT (E90); BMW 330i (E91); Elise (S1); Skoda Fabia VRS (Mk1); Peugeot 106 GTi; Skoda Octovia VRS (Mk2 estate); Subaru Impreza WRX (Wagon); Subaru Impreza Turbo (Wagon); Lancia Delta Integrale Evo; Golf VR6; Peugeot 205 GTi 1.9; BMW M3 (E30); Peugeot 106 GTi; Renault Clio 16v; Peugeot 205 GTi 1.9; Escort Mk3; Escort Mk1
Post by hap » Sat Nov 14, 2020 5:12 pm
I’ve just seen a 1100nhp Nissan skyline today at a mates tracked in semi slick for a detai and that was absolutely filthy but looked sexy as
+1 pics of a dirty alpina 🙏🏻
