Locking wheel nuts Z4 Alpina
dkatwa
Post by dkatwa » Mon Aug 10, 2020 12:11 pm
Nut missing.jpg (560.47 KiB) Viewed 1170 times
hi
I cannot find the nut key for my Z4 Alpina. I contacted LWNK but since it's not a BMW product, they cannot help. Does anyone on here recognise the type of nut I need please? the picture is not clear and from one of the pix, it looks like there is a black collar around the stud. however, the stud is normal length (maybe 1 inch) which i hope you can make out from the second picture. thanks
thanks
deepak
Nut missing 1.jpg (545.05 KiB) Viewed 1168 times
Henry
Re: Locking wheel nuts Z4 Alpina
Post by Henry » Wed Aug 12, 2020 2:13 pm
I have similar looking locking nuts on the x5 but all the patterns are different. In the past I have had success beating a socket that nearly fits on, to the other extreme of getting a piece of thick rod welded on then a sturdy tube to undo. A complete PITA.
B3 1999 (090)
E30 M3 1990
X5 4.6is
VW Mk4 R32
PerryGunn
Post by PerryGunn » Wed Aug 12, 2020 4:02 pm
There are some sockets that have a lot of little push rods that are supposed to fit misshapen or irregular nuts, I understand that some of these will work on keyed bolts
Alternatively, the tyre changing places often have a variety of locking-nut 'keys' - if you have a spare 'normal' bolts, it might be worth swinging by one or two and offering a fiver for a beer if they can get the keyed ones out and replace them with the standard ones...
Alpina Roadster S #320
BMW X3 F25 LCI 30d
dkatwa
Post by dkatwa » Thu Aug 13, 2020 10:37 am
hi Perrygunn...thanks for the suggestion...I was due to get MPS4s all around this weekend but that garage told me they cannot take the wheel nut off....so cancelled my appointment for the moment. ordered some bits off amazon that might do the trick....will keep you posted
dkatwa
Post by dkatwa » Thu Aug 13, 2020 1:44 pm
Got them off finally! Bought the below from Amazon. however, none of my wrenches fitted so ended up buying a 3/8 inch wrench also from Amazon and took about 5 mins to get them all off.
Will look to buy McGard replacements now.
https://www.amazon.co.uk/dp/B07PPF5NNS/ ... nFbQV1WTQC
thanks for the replies everyone!
Bob
Post by Bob » Thu Aug 13, 2020 2:09 pm
Good news that you got the nuts off (although a little disheartening to hear they are that easy to remove with the right tool!)
PhillV8S
Post by PhillV8S » Thu Aug 13, 2020 2:39 pm
It’s like a lot of security precautions unfortunately, easily bypassed if someone wants to make a small effort. Security bolts are just a veneer of security. Cheaply and easily removed if required. If the toe rags can be bothered to walk around with a jack and wrench then the universal socket isn’t really much to add to their toolkit to make their job easier.
Range Rover SDV8.
Maserati Gransport
Bob
Post by Bob » Thu Aug 13, 2020 11:19 pm
Guess I know that really, it's usually just a case of making your car more awkward than another so it's not the easiest option for the tea-leaves.
PerryGunn
Post by PerryGunn » Fri Aug 14, 2020 8:15 am
The wheel bolt designs that just have an irregular outer surface have never offered much protection - the McGard ones with a smooth outer surface and rotating collar are much better.
Anything like this is just a deterrent, these days the scroats are probably more likely to take the whole car than the alloys...
BMW X3 F25 LCI 30d
