Alternator off today to replace the current-voltage regulator that's what I call it or the potentiomet on the parts box that's what BMW calls it.
what I can say it's not the easiest of jobs but decided to remove the alternator from the bottom of the car that way I could leave the supercharger in place just glad I have got small hands or I would have had to tell the wife to do it.
My B5 Alternator off today.
B6 convertible 4.4 black with silver decals .
B5 saloon 4.4 black with silver decals .
Not much room in there is there!!! I take it that you have a ramp or a pit.
What issue were you getting that needed that part changing?
Current Cars
2010 Alpina B3s Cab (233/Deep Sea Blue)
2002 Alpina B10 V8s (96/Avus Blue)
2008 Alpina B5s (453/Sapphire Black)
2007Alpina D3 MT (348/Titanium Silver)
2009 Honda S2000 (Black/Red Leather)
1999 F355 F1 Spyder (Black/Beige Leather - US Spec)
1988 BMW E28 M5 (Black/Natur Leather - US Spec)
1988 Volkswagen Golf GTI MK2 8V - looking sad for itself and to be renovated!!
Previous Cars
Renaultsport Clio 172
Volkswagen Scirocco
Vauxhall Cavalier SRI
Various Vectras, Laguna's, 406's etc - for work
Previous Cars
Volkswagen Scirocco
No ramp or pit just two big jacks and a crawling board. The first issue was Tracker rang to say my car was being stolen then my speed camera detection equipment gave a warning of low voltage 11.8 to 12.0 when running but all the time a had no warning lights on the dash so plug in my Foxwell code come up with 28D7 DME not communicating with the alternator. basically, it had a dry joint because when the car was hot and restarted it would go back to 14.0 volts.ABRAD wrote:Not much room in there is there!!! I take it that you have a ramp or a pit.
Re: My B5 Alternator off today.
Resurrecting an old thread, but mine is also intermittently not charging.
Disconnecting the IBS doesn't make any difference. At 155k miles, maybe it's a dud regulator, perhaps a dry joint, or just worn out brushes. Whatever, it looks like alternator out and probably a recon unit, since at this sort of mileage the whole thing is probably on its last legs anyway.
Winne1, like you and for the same reasons, I am planning to remove from below. From your pics it looks as if you unbolted the power steering pump; if so, did you need to disconnect the pipework, or just move it all out of the way?
E60 B5 Number 86
E34 M5 Touring - gone
E34 540i 6sp - gone
E3 3.0Si - long gone
1600-2 - long gone
E34 540i 6sp - gone
1600-2 - long gone
Hi Sam, No need to disconnect the pipework just move it all out of the way.
Thanks, that was the answer I was hoping for!
E60 B5 Number 86
E34 540i 6sp - gone
1600-2 - long gone
E34 540i 6sp - gone
1600-2 - long gone
