realise this is a bit of a fantasy but am after an ecu for a b10 3.5 e24
thanks
ECU B10 3.5 E24
ECU B10 3.5 E24
C12.3 E21 1982 black/silver
B10 3.5 E24 royal blue/gold
D3 E90 Touring blue/ivory SELLING
B9 3.5 E28 SOLD gold/green
B9 3.5 E24 SOLD black/silver press car
B3 3.0 CAB SOLD 1994 alpina blue/gold
Re: ECU B10 3.5 E24
Do you know that an e24 B10 ecu is just a std BMW ecu with an Alpina derived chip fitted instead of the BMW chip? I think the std ECU is the 0261200404 or 179 item fitted to various BMWs of that era.
Finding one is going to be very hard BUT someone like Enda Ward can supply chips to replace that fitted within a std ECU with the necessary tune (sometimes improved state of tune) and relevant details applied. So is yours missing or damaged?
https://www.endtuning.com/about.html
2000 e39 B10 V8 Touring
1985 e23 B10 (sold)
1985 e23 B10 (sold)
Re: ECU B10 3.5 E24
thanks so much for that information.
i wasn't aware of any of that.
it turns out my b10 has the wrong engine so in the process of fitting the correct one and trying to get an ecu to match.
really appreciate the reply. thank you
Re: ECU B10 3.5 E24
ah I see, the car will run on a std ecu but the fueling and timing will be way out.
1985 e23 B10 (sold)
1985 e23 B10 (sold)
Re: ECU B10 3.5 E24
ok. so hopefully with the new chip from the link you supplied I will be able to correct that?
Re: ECU B10 3.5 E24
yes it would and probably be a slight improvement over the original
1985 e23 B10 (sold)
1985 e23 B10 (sold)
