B10 3.3 ECU Issue
herbie75
B10 3.3 ECU Issue
Post by herbie75 » Fri May 12, 2023 3:32 pm
Hi All,
car was occasionallly slipping into Engine Failsafe Prog (limp mode), but would toggle of the ignition would make it go away. Now a permannt feature and car is in with specialist. Previously I had throttle body replaced, which they've just tested alongside the wiring to the ECU and all fine. This then leads to possible ECU issue. ECU being sent off to be put on rig and tested to see if it has an issue, then let me know if repair or clone options exist.
Anyone else had exprience of replacing/cloning/repairing ECUs on a B10?
Many thanks!
Elliot.
B10 3.3 Touring #14 Manual in Sienna Red II with Gold Decals
