Small oil substance patch rear offside e46 B3s?
Post by hap » Wed Oct 20, 2021 9:13 am
Backed out garage and noted oil on floor
Is this likely to be diff output seal ? Or leaking shock ? Will monitor and get it checked out by garage if more tomorrow
Ta
rc944
Re: Small oil substance patch rear offside e46 B3s?
Post by rc944 » Wed Oct 20, 2021 10:33 am
you 100% sure the leak originated from that area? would be really surprising if there is a drip from the output seal or shock. they usually weep first and you would have seen signs before?
is it def oil and not brake fluid?
Post by hap » Wed Oct 20, 2021 2:38 pm
Well it was hard to see but I think u have a good shout at that I’ll put some card under it tonight see what Happens
Post by hap » Fri Oct 22, 2021 8:16 am
This morning
rc944
Post by rc944 » Fri Oct 22, 2021 10:50 am
get it on a ramp - wonder if its a failing seal/crush washer on diff drain plug or maybe input shaft seal. no biggie either way but best to get it inspected
