Using coolant
Tonyfraser
Using coolant
Post by Tonyfraser » Fri Jun 11, 2021 12:19 am
Hi guys. I have a D3 Bi turbo on an 58 plate. I’m using a lot of coolant. About a litre a week. I can’t find any physical leaks and it’s not overheating. Are there any known issues with head gasket going and not pressurising the system? No water in the oil and no carbon smells in the expansion tank. Any advice will be greatly appreciated.
Bri-E
Re: Using coolant
Post by Bri-E » Sat Jun 12, 2021 7:47 pm
Hi Tony, you may EGR issues, if yours hasn't been changed by BMW recall. Suggest you check that out as a possible answer
Bri-E
D3BT Touring (2014) #015
D3BT Touring Swithtronic (2012) #402 Sold
D3 (2007) #538 (Sold but remembered)
120d Sport (2004)
318ti SE Compact (2001)
318tiSport Compact (1998)
318ti Compact + Sport pack (1995)
Ford Capri 2.0 Laser (1985) 205,250 miles passed
Tonyfraser
Re: Using coolant
Post by Tonyfraser » Sun Jun 13, 2021 9:50 am
Thanks for that. I’ll have a look into it. I have had a dpf removal and recode. Plus the egr was capped off. Could be the issue. Cheers.
Wellsy
Re: Using coolant
Post by Wellsy » Fri Sep 24, 2021 11:56 am
I know it's been a while but did you fix this?
I have a 2009 D3 BT and had coolant issues, now fixed so might be able to share some ideas if its still going on.
Cheers Mark.
E90 D3 Biturbo 2009 No114
Black with Gold Decals
Piano black interior trim (looking for trim with Gold inlay, watch this space :P )
Upgraded Stereo system
