Brake discs for Alpina d3 Biturbo 2010
Nage
Post by Nage » Wed Mar 31, 2021 6:42 pm
Does anybody recommend any Brakes discs for my Alpina, can only find rear brake discs didn’t want to go to the dealer and get ripped off?
Nage
D3 2010
ttrill
Re: Brake discs for Alpina d3 Biturbo 2010
Post by ttrill » Wed Mar 31, 2021 6:54 pm
Front brakes are from a 330D/i so pretty easy to source. Size is 330mm
I have Padgid on mine. Pretty good under high loads, If you do get them make sure you get the German built ones as production is switching to China and I doubt they’ll be as good.
ATE will also be good but I have heard mixed reviews about the Brembo discs.
Toby
2011 D3BT #454
2019 440i Gran Coupe
Nage
Post by Nage » Wed Mar 31, 2021 7:02 pm
The ones from the 330d would this be from e90, sorry am quite new to the site and got a lot of newbie questions. We’re can I find them?
Nage
D3 2010
Nage
Post by Nage » Wed Mar 31, 2021 7:25 pm
Hi mate what year from the 330d would this be?
Nage
D3 2010
Nage
Post by Nage » Wed Mar 31, 2021 8:00 pm
This is what I’ve found on Euro car parts Product Code: 104111098
Is this right?
Nage
D3 2010
ttrill
Post by ttrill » Wed Mar 31, 2021 8:15 pm
Is this right?
Yes these are what I have, lots of great knowledge on here so don’t hold back any questions!
Toby
2011 D3BT #454
Nage
Post by Nage » Wed Mar 31, 2021 8:43 pm
Thanks for the help, what about the rear brake discs can you use the same car?
Nage
D3 2010
Bob
Post by Bob » Wed Mar 31, 2021 11:45 pm
I've linked all the parts catalogues in this post.
These detail all the ALPINA changes from the base/donor vehicle for your car. If a part isn't specifically listed then you should be able to use your original BMW VIN (starts WBA*****) to search parts in www.realoem.com.
In the catalogues, where you have a 7-digit number these are ALPINA parts that you will need to source direct from ALPINA/official parts supplier, otherwise the 11-digit numbers are a BMW part number, just not from your donor vehicle so you should be able to get them from ECP or where ever you like.
Nage
Post by Nage » Thu Apr 01, 2021 12:34 am
Oh okay, still trying to figure out about the rear brake discs, any quick answers?
Nage
D3 2010
Bob
Post by Bob » Thu Apr 01, 2021 1:11 am
The part number is in the catalogue: 34 21 6 855 004
Should be standard E9x rear vented disc from a 330d
Nage
Post by Nage » Thu Apr 01, 2021 9:58 am
Thanks but Sorry to be a pain this is what I have found Pagid Brake Disc (Rear)Product Code: 104111058 but there small than the front is that correct?
Also the 330 BMW is that coupe or salon?
Nage
D3 2010
Bob
Post by Bob » Thu Apr 01, 2021 10:42 am
34 21 6 855 004 is common across all platforms. The part number you have appears to be a 300mm disc not the 336mm specified in the ALPINA catalogue.
Googling 34 21 6 855 004 throws up quite a few options, for example:
https://www.autodoc.co.uk/car-parts/oem/34216855004
Nage
Post by Nage » Thu Apr 01, 2021 11:29 am
This only seems to be the rear brake discs, they don’t seem to do the front ones and I didn’t want to mix brands. Do you know we’re I could get both from which are the same brand?
Nage
D3 2010
Bob
Post by Bob » Thu Apr 01, 2021 11:49 am
The front discs are p/n 34 11 6 854 999 which are also available on Autodoc (https://www.autodoc.co.uk/car-parts/oem ... r%5B0%5D=2)
Hella & Pagid are the same company: https://www.hella-pagid.com/hellapagid/en/index.html
Nage
Post by Nage » Thu Apr 01, 2021 12:09 pm
Life saver thank you very much
Nage
D3 2010
