Gear Selector Light
Rav
Gear Selector Light
Post by Rav » Sat Feb 27, 2021 5:06 pm
Dear friends - I have just collected my car from BMR after fitting the suspension and a few other bits. The drive back was sublime a real difference - thanks to @charles for showing what an Alpina is supposed to ride like. No coilovers for me!
The journey home was long and I have just pulled up home and moved the gear selector from D to P and noted that the little yellow light that tells you which gear the car is in is no longer working.
Any help with this please? I hope its something I can do myself as i need to break the news to the wife that the suspension and fitting was £3k!
Re: Gear Selector Light
Post by Metrics » Sat Feb 27, 2021 5:14 pm
Wowzers Rav, I though the kit was £1300 odd?
Sorry can't help with the light thing - lose connection, or the bulb or switch?
2012 Alpina D5 BiTurbo No. 13
2002 Alpina B10 V8S No. 60
2005 Audi TT 225
1983 Mk1 Golf GTI
Rav
Post by Rav » Sat Feb 27, 2021 5:19 pm
Thanks Metrics.
The kit was just over £1300 once delivered. It got stuck in europe with the wrong paperwork after Brexit! Fitting was not bad value from the BMR team at something like £600, but whilst the car was there, I added a few items to the list - gearbox flush, brake fluid change and a few other bits.
Lat thing i needed was the light not to work, but, 'classic cars - who would have 'em'?
Post by Charles » Sat Feb 27, 2021 5:28 pm
Probably just a loose connection on the bulb. You can check this by lifting the trim around the gear selector.
Really pleased that you finally have the proper suspension set-up 👍
Post by Metrics » Sun Feb 28, 2021 10:06 am
Ah I see, soon mounts up!
Enjoy
2005 Audi TT 225
1983 Mk1 Golf GTI
davettf2
Post by davettf2 » Sun Feb 28, 2021 11:09 am
Hi Rav Not sure if this will help, I'm assuming that your E46 has a 'pixel' dash panel, The details below , hopefully!, gives access to the ability to check all the instrument cluster illumination.
BMW E46 Hidden Codes
Instructions to access the hidden OBC functions:
 1. Hold Trip Reset while turning ignition key to on position
 2. OBC should show "Test"
 3. Use Trip Reset to select function 19.0 that unlocks all the features
 3. Wait for display to show "Off"
 4. Depress Trip Reset for 1/4 second and release it
 5. With no delay press Trip Reset several times to select one of the following functions
BMW E46 On-Board Computer (OBC) Hidden Codes:
1 Car Engine and cluster data
 1.0 46nnn Chassis nr/VIN serial number (last 5 digits)
 1.1 4nnn K-number
 1.2 690236 Cluster Part #
 1.3 045210 Coding (04)/diagnosis (52)/bus index (10)
 1.4 1200 Week (12)/year of manufacture (2000)
 1.5 09_160 Hardware (09) and software # (16.0) of cluster
 1.6 Not used
 1.7 04__44 CAN-version (04) KI-revision index (44)
2 (test) Cluster System Test - Activates the gauge drivers, indicators LEDs to confirm function
3 SI Data
 3.0 1098 Used fuel in liters since last SI (Service Inspection)
 3.1 0231 Periodic inspection days; elapsed days (since last SI)
4 Momentary Consumption
 4.0 0145+ Instant fuel consumption - 0145=14.5 liters/100km
 4.1 0018 Instant fuel consumption - 0018=1.8 l/Hour
5 Distance Gone Consumption
 5.0 082 Average mileage; 082=8.2 liters/100km
 5.1 0536 Calc. km to refuel (momentary distance to go)
6 Fuel Level sensor inputs in liters
 6.0 109330+ Fuel level averaged; Left half sensor input=10.9 liters; Right sensor input=33.0 liters
 6.1 0439+ Total tank level averaged; vlgs 6.0: 10.9+33.0=43.9 liters
 6.2 0442+ Indicated value (44.2) and tank phase
7 Temperature and Speed
 7.0 021+ Coolant/Engine temperature (2.1C)
 7.1 130 Ambient/Outside temperature - chg met 5 pts. 125/130/135
 7.2 + Engine speed / Current RPMs 1/min
 7.3 + Vehicle speed / Current Speed in km/hour
8 Input value in HEX form
 8.0 1d0+ System voltage ADC-Value Hex code
 8.1 26C33C+ ADC Values HG left/HG right
 8.2 0000 ADC Value brake degradation sensor (000=o.k.)
 8.3 18C ADC Value outside temperature
9 Battery
 9.0 140 Battery Voltage - 140 = UB 14.0v
 9.1 242013+?
 9.2 074_78+?
 9.3 0011+?
10 Not used
11 Not used
12 Not used
13 GonG Gong Test
14 Not used
15 Status cluster I/O-ports (bit codes) 0=low; 1=high
 1 belt contact, seat belt fastened=0;
 2 ignition lock contact, key inserted=0;
 3 door contact, door open=0;
 4 clock button pressed=0;
 5 SI reset=0, for reset=0;
 6 EGS transmission failure=0
Status Digital Outputs (bits) 0=inactive, 1=active
 1 Gong output;
 2 Brake warning lamp;
 3 Low fuel warning lamp;
 4 EGA lamp;
 5 seat belt lamp;
 6 manipulation dot
16 Not used
17 Not used
18 Not used
19 Lock Status; unlocks functions in range 3-18
 19.0 L-On/L-Off Unlock: press button when "L-Off"
20 Not used
21 Software Reset; reset OBC settings
00 End of test
Dave
Rav
Post by Rav » Sun Feb 28, 2021 12:04 pm
Wow - thanks Dave. I will give that a look. I have never seen this before. What a great resource!!
Post by Charles » Sun Feb 28, 2021 1:13 pm
Rav - just to clarify - is it the orange light on the centre console next to the gear lever or the display on the dash?
Rav
Post by Rav » Sun Feb 28, 2021 4:46 pm
Good point Charles - I got excited.
Its the little yellow light next to the gear selector informing you of which position the lever is in.
Mine was temperamental and no have given up. I checked a few forums and it seems that wires wear away under here.
https://www.e90post.com/forums/showthread.php?t=511799
I will investigate in detail tomorrow.
Rav
Post by Rav » Sun Feb 28, 2021 6:39 pm
Ok, so i went out the car and its now working fine.....Madness!
CaesarBob
Post by CaesarBob » Sun Feb 28, 2021 10:57 pm
Definitely sounds like you've probably got a wiring issue. Most likely there is a wire which is wearing through or is breaking due to following a convoluted path.
