B10 V8S illuminated door sills
Hi all
I understand the door sill trims on the V8S are illuminated versions but are prone to failure quite early on in their life.
Mine don't work - anyone aware of a fix? Been searching online but given the rarity of these cars not much to find!
Our E39 M5 had those, but I cant say that we ever had any problem with them. They must all work in the same way though. ie, same wiring and internals. Just different badging.
1997 E36 Alpina B3 3.2 Touring. No.66
1998 E36 1.8 Touring
1989 E30 M3.
2004 E60 530D
2004 Vauxhall Signum (for the shopping)
2002 E39 M5 (Sold)
1989 E30 M3.
2004 E60 530D
2002 E39 M5 (Sold)
There was a member on here who had the same problem and if i recall came up with a way of fixing them but i can't remember who it was.Maybe another member will point you in the right direction or ,failing that try a search on here.
On a mission to burn as much fossil fuel as possible before it runs out.
This one?BarryM wrote:Run a search, I posted a link that gave some info, not sure it actually helped but it did give some pointers.
http://www.thealpinaregister.com/forums ... ae6200e3a6
First you need to find which component has failed on your sills. If all 4 are off it might be a supply issue so check the input and output from the voltage invertors which are located in the bottom section of the "b" pillars (see pics from previous thread as highlighted).
Range Rover SDV8.
E64 B6s #100 Cabriolet (Now Sold)
Maserati Gransport
Maserati Gransport
Thanks Phil, some investigations required!PhillV8S wrote:First you need to find which component has failed on your sills. If all 4 are off it might be a supply issue so check the input and output from the voltage invertors which are located in the bottom section of the "b" pillars (see pics from previous thread as highlighted).
Appreciate the guidance.
