Using coolant
Tonyfraser
Using coolant
Post by Tonyfraser » Fri Jun 11, 2021 12:19 am
Hi guys. I have a D3 Bi turbo on an 58 plate. I’m using a lot of coolant. About a litre a week. I can’t find any physical leaks and it’s not overheating. Are there any known issues with head gasket going and not pressurising the system? No water in the oil and no carbon smells in the expansion tank. Any advice will be greatly appreciated.
Bri-E
Re: Using coolant
Post by Bri-E » Sat Jun 12, 2021 7:47 pm
Hi Tony, you may EGR issues, if yours hasn't been changed by BMW recall. Suggest you check that out as a possible answer
Bri-E
D3BT Touring (2014) #015
D3BT Touring Swithtronic (2012) #402 Sold
D3 (2007) #538 (Sold but remembered)
120d Sport (2004)
318ti SE Compact (2001)
318tiSport Compact (1998)
318ti Compact + Sport pack (1995)
Ford Capri 2.0 Laser (1985) 204,400 miles passed
Tonyfraser
Re: Using coolant
Post by Tonyfraser » Sun Jun 13, 2021 9:50 am
Thanks for that. I’ll have a look into it. I have had a dpf removal and recode. Plus the egr was capped off. Could be the issue. Cheers.
