Ok so im unable to upload the pic but anyway on my dash under service items there's a pic of a dpf with a red fan above and a small orange triangle
Does this mean the dpf won't regenerate ?
Dpf regeneration
Which model car is it?
If its a pic of a filter with a fan it is likely to be the pollen filter. On the D3 this is in the engine bay buy the windscreen - a few screws and an easy DIY change, I've just picked up a Mann filter for mine
https://www.ebay.co.uk/itm/Mann-FP8430- ... 2308924834
If its picture of a baked bean can on its side, half shaded then its the DPF.
If the DPF symbol has come up then it is likely your car will hesitate if you try and go over 3000 rpm approx and you'll need to get a garage to arrange a force regeneration and read the codes.
If its the symbol like the one at post 9 then its the pollen filter that needs changing:
http://www.e90post.com/forums/showthread.php?t=738839
I just changed mine for one of these on the weekend:
https://www.eurocarparts.com/ecp/c/BMW_ ... d38&000047
https://www.youtube.com/watch?v=aOOuTgtV0So
