Trigger's Broom
nealpina
Post by nealpina » Thu Aug 11, 2016 12:15 pm
Charles wrote:
nealpina wrote:Not heard of this happening on IL6 before, but I believe this is a common complaint with V8's of this era.
A quick google for "zf5hp19 2nd 3rd flare" reveals that this is more common than you might think :shock:
Cheers for the update
nealpina
Post by nealpina » Thu Aug 11, 2016 12:21 pm
Charles wrote:Biting the bullet
Hope it's not too costly Charles
Also make sure you always have a photo of the you with the car, so that you have the proof that it is the same car - as per Tigger's Broom 😀
Edit the 'smile' smiley is from the iPhone instead from the forum list. It looks different in different browsers.
Post by Charles » Thu Aug 11, 2016 9:52 pm
Been doing a bit more digging and have found this
If this is the case then it may not require a full rebuild. As it is part of the valve body then this should have been done recently, so I will need to check out exactly what was replaced. If it has been renewed, then the problem is the F clutch itself, but it is curious that it is only happening when hot.
If anyone is knowledgeable about the guts of the gearbox then please can you point me in the right direction.
Post by Charles » Sun Aug 14, 2016 11:59 am
Fingers crossed for tomorrow.
After several phone calls, it appears that when the valve chest was refurbished, the D & F clutch accumulator piston cap O rings weren't changed as there was no indication on the test bed that they were passing oil. The test involved running the chest through a series of actions at different oil temperatures, so it should have picked it up. But, a few minutes at 100oC on a test bed is not the same as operating on the road when not only is the oil at temperature but all the internal parts have reached the same temperature.
As such, I have delayed taking the car to the gearbox specialists by at least a day so that we can fit new O rings and see whether that does the trick. A relatively straight forward job which could save me quite a lot of money :shock:
I am trying not to get too hopeful but logic suggests to me that if there was a problem in the mechanicals then it would show itself straight away rather than a very predictable 40 minutes or so into a journey, once everything is properly to temperature.
Only time will tell ...
MCB
Post by MCB » Sun Aug 14, 2016 10:55 pm
Good luck Charles and fingers crossed for you :D
1998 E36 1.8 Touring
1989 E30 M3.
2004 E60 530D
2002 E39 M5 (Sold)
Post by Charles » Mon Aug 15, 2016 8:52 pm
Having got all excited when we got the old O rings out and saw how they were worn, I made it as far as the slip road for the M40 at Beaconsfield and the box starting flaring again.
Heading up to Hertfordshire to the gearbox specialists tomorrow for whatever they think is needed ...
Post by Charles » Mon Aug 22, 2016 3:38 pm
Found the culprit!
The F drum has worn out and needs replacing. Having a full refurb of the gearbox and TC - both hard and soft parts this time - including specially machined shims to ensure optimal tolerances.
So now I know that the friction surfaces are good for 190k miles and the drums start to wear out at 280k miles!
Expensive but worth it (I hope) ...
kith
Post by kith » Mon Aug 22, 2016 4:36 pm
280,000 miles!!!??!! That's extraordinary! Have they all been under your tenure?
CURRENT: 2021 Alfa Romeo Giulia Quadrifoglio
SOLD SEP '20: 2009 Porsche 911 Carrera
SOLD JAN '17: 2014 BMW M135i Auto
SOLD FEB '14: 2008 B3 Bi-Turbo Coupe #156
Post by Charles » Mon Aug 22, 2016 5:35 pm
kith wrote:280,000 miles!!!??!! That's extraordinary! Have they all been under your tenure?
All mine :D
kith
Post by kith » Mon Aug 22, 2016 10:46 pm
Brilliant! Surely there can't be a higher mileage one out there?
Post by Charles » Tue Aug 30, 2016 3:26 pm
Yay! :D
Guess what is back on my drive?
Had a good run back from Ware in Hertfordshire and it is clear that I need to get used to what is essentially a new gearbox with everything back to OEM tolerances along with a refurbished TC that locks up properly - it appears that my instinct that it wasn't locking up correctly since the previous refurb was right as it was observed that the tolerances in the TC were way out when they opened it up.
Also, I'm not sure that they have replaced the exhaust correctly as it is a bit "boomy" but the next couple of weeks of running-in before I pop back for a 1000 mile check-up will give me time to get used (or otherwise) to the new sounds and feel.
Added bonus was that I got over 30mpg on the way back - long may that continue :D
Post by simon13 » Tue Aug 30, 2016 8:52 pm
good, have they left the vacum pipe off the the exhaust valve in the tail pipes? Ours is like it on purpose and can be a bit boomy but i like it
Post by Charles » Tue Aug 30, 2016 8:55 pm
Just popping out to check and refit if missing - thanks Simon :D
Post by Charles » Fri Sep 02, 2016 11:27 pm
Curiouser and curiouser!
It appears that the booming is associated with the "new" gearbox and is beginning to reduce as the box "beds in".
All the more reason to get some more miles on the clock - quickly :twisted:
BarryM
Post by BarryM » Sat Sep 03, 2016 8:36 am
Great news, good to see that the gearbox can be re-built so successfully. For some reason I thought this wasn't possible, mine has had the oil flush as a precaution a few years back and seems to work perfectly but you never know what's round the corner.
