Alpina d3 loss of power
Rs6mick
Post by Rs6mick » Mon Oct 02, 2017 10:47 pm
Hi I have a d3 single turbo and it's lost its power still drives but turbo not cutting in I've been working on this for over a week now and so far have discovered there is nothing wrong with the following
Turbo is fine
Electronic actuator is fine
Air mass sensor is fine
I've cleaned the egr
I've plugged it in to a computer and it's now saying something to do with the oxygen sensor and glow plug system but I'm sure the is because there is no boost at present has anybody else ever experienced the same thing and fixed the problem if so please help
toddy2
Post by toddy2 » Tue Oct 03, 2017 6:56 am
Any warning symbols? Maybe the DPF is blocked?
2011 D3 BT Grey Touring(Incoming!)
2007 Alpina D3 E91 Montego Blue Touring (SOLD)
2003 BMW E39 M5
Arvi
Post by Arvi » Fri Oct 06, 2017 2:02 pm
If DPF blocked it can sometimes be due to failed glow plugs/glow plug controller unit which prevents auto regen, but you usually get the DPF error light come up. Worth getting the controller unit done as well if it is glow plugs otherwise fault reoccurs.
DonFlintoni
Post by DonFlintoni » Wed Oct 11, 2017 11:16 pm
From my recent experiences id say DPF is blocked. Probably cause is a failed plug/ plug relay.
When the DPF is blocked power is limited which is quite unsettling when your used to the usual wall of torque at 2000 revs.
Former Alpina owner. Having a break.
vv3bby
Post by vv3bby » Thu Oct 12, 2017 9:29 am
i have a similar issue - but mine drops at around 4000 then kicks back in less than a second later (noticed in 3rd and 4th...) would this be a DPF problem too??
Stuck_mojo
Re: Alpina d3 loss of power
Post by Stuck_mojo » Sat Feb 29, 2020 12:19 pm
Replying to an old thread, my D3 MT is doing this now. no turbo surge - drives fine, no rattles or warning lights. fuel consumption is fine and motorway cruising at speed limit or thereabout is fine.
Thoughts?
2015 Porsche Macan S
1998 Porsche 911 C2 Manual
2015 BMW 220i Convertible MSport
DogWagen
Post by DogWagen » Sat Feb 29, 2020 11:55 pm
Have you checked for any fault codes and/or coolant temp?
Stuck_mojo
Post by Stuck_mojo » Sun Mar 01, 2020 11:03 am
Hi, my cheap one shows no issues. How do I check coolant temp? I'm servicing the car next week. Hopefully not a serious issue ?
DogWagen
Post by DogWagen » Sun Mar 01, 2020 8:56 pm
Have a look on your code reader - if it's similar to mine (C110), you should be able to read the data stream. Failing that there's a hidden menu on the dash (Google will find the how-to access it).
If the coolant temp is low and/or you have issues with glowplugs/relays, the dpf won't regenerate and will start to clog up, particularly if you do lots of short journeys and/or start/stop. Hope that helps.
Stuck_mojo
Post by Stuck_mojo » Mon Mar 02, 2020 2:49 pm
Hi,
answering my own question here, the DPF light came on. I guess that explains it.
What's the easiest/less costly way to fix? I'll have the car serviced at the same time.
Edited - having done a bit of reading, my car has 150,000 miles but mostly lives at 75MPH on the motorway in 6th. Is the DPF/CAT the same as the same year 320D?
https://www.cats2u.co.uk/bmw/34197-bmw- ... 6051t.html
if that's the case I'm not too fussed about buying a new one.
DogWagen
Post by DogWagen » Mon Mar 02, 2020 10:20 pm
Assuming yours is a monoturbo.... Have a look at the D3 parts catalogue https://www.thealpinaregister.com/downl ... 3_2005.pdf. If not, I wonder if any of the specialists on here could advise you.
If it helps, I've had 2 bmw diesels (352d and 335d) with dpf both of which have done ~150k without any dpf issues and like you, lots of motorway journeys. Both had thermostat changes and one required glowplugs and a relay to make the dpf regenerate. I have a feeling you may have an underlying cause to be solved to prevent a recurrence but will defer to others.
Stuck_mojo
Post by Stuck_mojo » Mon Mar 02, 2020 11:30 pm
Thanks, yes mine is a monoturbo. Curiously, since the DPF light has been on, some of the power has come back.
I'll do a major service and ask a specialist to look at it. Will update. (i'm doing a very long trip tomorrow and let's see what happens if I keep it in 5th)
Stuck_mojo
Post by Stuck_mojo » Wed Mar 04, 2020 10:14 am
Update - Major service by a renowned NE specialist on Monday and let's see what the problem is. I'll update then.
DonFlintoni
Post by DonFlintoni » Mon Mar 09, 2020 10:53 pm
Hi,
Whatever you do, dont fit an aftermarket DPF.
Buy a genuine one.
The cars dont get on with the pattern part.
Ive first hand knowledge of that problem.
Hopefully your problem is a quick fit. BTW the recommended 'life' for a DPF is 120,000 miles. They can last a lot longer if well looked after. Unfortunately the car is not good at reporting DPF faults til its too late. A code reader is invaluable.
Stuck_mojo
Post by Stuck_mojo » Wed Mar 11, 2020 2:29 pm
Car goes in on Friday.
good point on aftermarket DPF>
If it needs it replacing I'll buy one on eBay or scrapyard - assuming the part is a BMW one.
