Locking wheel centre cap jammed
I can't get one of my locking wheel centre caps off - the lock is sized/ won't unlock.
It's been soaked with WD40 and tapped a bit to try to free the lock but to no avail (yet).
Is this a common issue? Any ideas on what could be done before I have to drill the lock and seek a new centra cap/disc?
Thanks in advance.
Max
Thanks in advance.
Max
D3 BiTurbo #078
TVR V8S
TVR S3 - sold April '16 due the V8 arriving
TVR V8S
Have you tried pushing the cap in towards the wheel as you try and turn the key?
It may be that the locking arm is very tight against the wheel and by pushing the centre cap might give enough clearance for the lock to turn.
Just do what I did and order a new set of locks and keys - as soon as they arrive the old ones started working fine!!!!!!
Not had any further issues for the last 2 years, but have kept the spare set just in case. (Let me know if you need to buy a set as I work in Chesterfield)
It's as if they know!
On a serious note mine just jammed after I'd taken it of the car - it started working as I'd started loosening the backnut that holds the lock barrel onto the cover - might help, but you have to get the cover off the car in the first place.
Good luck.
Good luck.
Current Cars
2010 Alpina B3s Cab (233/Deep Sea Blue)
2002 Alpina B10 V8s (96/Avus Blue)
2008 Alpina B5s (453/Sapphire Black)
2007Alpina D3 MT (348/Titanium Silver)
2009 Honda S2000 (Black/Red Leather)
1999 F355 F1 Spyder (Black/Beige Leather - US Spec)
1988 BMW E28 M5 (Black/Natur Leather - US Spec)
1988 Volkswagen Golf GTI MK2 8V - looking sad for itself and to be renovated!!
Previous Cars
Renaultsport Clio 172
Volkswagen Scirocco
Vauxhall Cavalier SRI
Various Vectras, Laguna's, 406's etc - for work
Previous Cars
Volkswagen Scirocco
That sounds just like my kind of luck - I'll give another go tomorrow.ABRAD wrote:Just do what I did and order a new set of locks and keys - as soon as they arrive the old ones started working fine!!!!!!
Good luck.
Might be back to you for your locks
Max
D3 BiTurbo #078
TVR V8S
TVR V8S
Any chance you might want to sell a barrel and key to a fellow suffere?sean7997 wrote:Same thing happened to one of mine, after trying for a while i drilled it out and replaced it. Now i have 3 other spare locks, i could only buy them in a set.
D3 BiTurbo #078
TVR V8S
TVR V8S
I've had a similar situation in the past and wished I had four hands to do the necessary - two to push the lock in and two to turn the key.
I'd suggest it's unlikely the lock has seized. Much more likely that the locking tab has corroded against the center rim making it very difficult to turn the lock. Spraying the lock mechanism with wd40 won't make any difference in this case.
You have to visualise what's going on behind the cap and take Simon13's advice on how to free the tab. Getting someone to help push the cap in as you turn the lock will also help.
I can imagine that, knowing how the lock operates. Will have to try bribing a mate to lend a hand for the price if a pint. I wonder if a bit of a tap with a smal punch and the persuader on or around the lock might work too.Chas wrote:I've had a similar situation in the past and wished I had four hands to do the necessary - two to push the lock in and two to turn the key.
D3 BiTurbo #078
TVR V8S
TVR V8S
2 people, 1 with a small bit of wood, the other to turn the key.
The first person, place the wood in the centre of the cap and hit with a hammer. DO NOT allow the wood to slide on the cap, it will damage it.
The second person, try and rotate key and keep constant pressure on the key.
As the impact works on the cap, the key will slowly rotate until the tab is free of the corrosion.
Once off, clean the tab and wheel, place copper grease on the tab before refit and it won't happen again.
Purchase the tool the presses the cap in before removal to assist in future and remove them frequently to prevent this issue in future!
1999 E36 323 Sport Touring
2019 Fiat Fullback
2019 Fiat Fullback
