B10 3.2 or 3.3 tie rods
Hi
I think I am needing some tie rods or bushes repaired on my front end. The car has now done over 130K and is making a clonking sound when reversing out of my drive on full lock each morning. I noticed on some forums there are upper and lower tie rods and might be worth doing all together (then pay for one alignment check) but that was on a 540(v8 ) so may be slightly different set up.
Any one been through repairs front end advise gratefully received
Slightly left field suggestion but how worn are your front tyres?
I ask because whenever my front tyres are close to replacement I notice a clonking sound on full lock when reversing out of a parking space.
This has happened every set of tyres since the car was new.
Not sure what is causing it, NOG have checked it once or twice and found nothing - the only common factor is worn tyres each time.
I have had the rear most Tension bars replaced on mine (which is number 11 in the diagram), i was informed the bush which was breaking up was not a seperate item so the whole arm had to replaced,:roll:
price was £125.11 + vat each, i had to have both done as both sides were on the way out,
the arm number 4 in the diagram has a separate bush and the previous owner had already replaced this with a polyurethane version,
if its not the anti-roll bar drop links clonking my guess would be the bush on the front most arm has worn and is kicking it over on full lock to hit the subframe bracket,
hope this helps you Brian, let us know how you get on.
<a><img src="http://static.bmwfans.info/images/epc/OTY1MDJfcA==.png" border="0"></a>
<a>BMW parts catalog</a>
Steve C
'94 325i Coupe SOLD
'94 325i Coupe SOLD
Both thanks very muchfor the replies. I think the tyres are ok so likely bushes. I had all the back bushes renewed in 09 so I think its the fronts turn.
I am thinking of going to Birds (not been before but they are quite convenient and not too costly, compared to a dealer)
Its great to have this diagram when you talk to someone fixing your car though.
I think I am going to name my car Bill
diagnosis from the garage is it is the brake reaction bushes which is the same as the control arm bush (according to cemessi here)
http://www.m5board.com/vbulletin/e39-m5 ... rakin.html
also getting the tailgate struts - all 4
exhaust air cold recirculation hose
gear lever bush
all sorted at birds, looking forward to the improved ride tomorrow
gear lever bush
That sounds like the number 5 bush in the diagram then on the front arm,b10brian wrote:diagnosis from the garage is it is the brake reaction bushes which is the same as the control arm bush (according to cemessi here)
gear lever bush
whats with the gear lever bush though Brian?
have you got a problem with it going a bit floppy in your hand?..........
sorry couldn't resist
Steve C
'94 325i Coupe SOLD
'94 325i Coupe SOLD
b10brian wrote:Ikule
Sometimes it takes a while to get it in!
Should be a snug fit once repaired :O
Steve C
'94 325i Coupe SOLD
'94 325i Coupe SOLD
