Alpina M62B48 engine differences between other M62 engines
I just acquired a non running Alpina Z8 that is said to need a new engine. I am assuming worst case scenario in this situation because it does not have any coolant in the reservoir. I am wanting to get the car running again, but I know that the block is not sleeved and is instead coated with alusil-severely limiting my options on saving the block. My question is, what are the differences between the alpina motor and the other m62 engines? Thanks!
Edited:not a B10 V8S sorry about the mix up. I had my uncle make the post for me and he must have mixed up the V8S and the z8 due to us having a conversation about the engines being the same. Sorry!
Re: Alpina M62B48 engine differences between other M62 engin
As far as I can remember apart from the cubic capacity the following changes were made to the standard engine.BCT wrote:I just acquired a non running B10 V8S that is said to need a new engine. I am assuming worst case scenario in this situation because it does not have any coolant in the reservoir. I am wanting to get the car running again, but I know that the block is not sleeved and is instead coated with alusil-severely limiting my options on saving the block. My question is, what are the differences between the alpina motor and the other m62 engines? Thanks![/img]
Crankcase
Crankshaft Sump top section
Cylinder heads
Camshafts
Head Gaskets
Valve Springs
Intake system and cover
Crankshaft
Pistons
Oil spraying Nozzle
Even the Oil dipstick tube is different
Only 145 Saloons and 43 Tourings were produced worldwide, so finding a spare engine would be very difficult.
What chassis number is your V8S Pictures would be great
If you can get it fixed, do you intend to register it in the states.
Unfortunately I have heard stories from other owners attempting to make their Alpina US legal.
So many changes have to be made which lose the Alpina DNA.
Sorry it is a Z8 not a B10. Is the 4.8 by any chance a stroked 4.6 or is the 4.8 a bored out 4.6?B10BRW wrote:As far as I can remember apart from the cubic capacity the following changes were made to the standard engine.BCT wrote:I just acquired a non running B10 V8S that is said to need a new engine. I am assuming worst case scenario in this situation because it does not have any coolant in the reservoir. I am wanting to get the car running again, but I know that the block is not sleeved and is instead coated with alusil-severely limiting my options on saving the block. My question is, what are the differences between the alpina motor and the other m62 engines? Thanks![/img]
Crankcase
Cylinder heads
Camshafts
Head Gaskets
Valve Springs
Crankshaft
Pistons
Oil spraying Nozzle
As the BMW V8 engine has Nicasil (later Alusil) coated bores the block can not just be over-bored. A whole new block was cast for Alpina by BMW with the displacement increased to 4.6. Alpina also made other changes to the engine with new crankshaft, more aggressive Cams, hand fettled Ports, lighter compression Mahle pistons, and reprogrammed Motronic system.
The V8S uses a modified version of the B10 V8 engine, the bore is exactly the same at 93mm, but the new crankshaft has increased the stroke from 85mm to 89mm which increases the displacement to 4837 cm3.
Other changes include a reworked and improved intake system and new piston rings.
This same engine was later used in the Z8 based Roadster , and even became a BMW production engine in the X5 4.8is
The N62 has Vanos and Valvetronic as do every other BMW engine with Valvetronic.E24man wrote:Sorry Brian, this is wrong.B10BRW wrote: This same engine was later used in the Z8 based Roadster , and even became a BMW production engine in the X5 4.8is
The B10 V8S and Z8 Roadster engine is the single Vanos M62B48 engine.
The E53 X5 4.8iS engine is the dual Valve-tronic (a different system completely from Vanos) N62B48 engine.
Vanos has a fixed camshaft profile, the timing of which can be varied against the stroke position of the engine; ValveTronic uses variable valve lift. The N62 also has a variable length intake manifold.
E39 B10 V8/1 #81
E28 B9 3.5 #536
plus a few other BMW's.
Previously enjoyed
E46 B3 3.3 coupe #274
E60 B5 #329
E46 B3 3.3 Saloon #450
E92 B3 Biturbo #185
E46 B3 3.3 Saloon #114
E34 B10 Biturbo #445
E36 B3 3.0 switchtronic coupe #185
E46 B3S convertible #34
Many other BMW's
E28 B9 3.5 #536
Previously enjoyed
E60 B5 #329
E92 B3 Biturbo #185
Many other BMW's
Sorry Kevin you are wrong.
The B10 V8S (375hp) is based on the N62 engine with Double VANOS with
variable valve timing also fitted to the exhaust camshafts (double-
VANOS).It has a bore of 93 mm (3.7 in) and a stroke of 89 mm (3.5 in).
Applications:
2002–2004 Alpina B10 V8S
2002-2003 Alpina Roadster V8
As quoted by Kees,
"N62B48 is the name of the BMW variant of the B10 V8S engine. It's pretty much identical to the Alpina engine but mass-produced instead of handbuilt. In the X5 4.8iS it produces 355hp and 500Nm. Convinced this is the same engine as the Roadster V8"
Applications:
As quoted by Kees,
If this is the case can I just buy a crankshaft, rings, bearings, etc.. out of an n62b48 and stick it directly into the m62b48?B10BRW wrote:Sorry Kevin you are wrong.
Applications:
As quoted by Kees,
Not sure who ‘Kees’ is but he is wrong.B10BRW wrote:Sorry Kevin you are wrong.
Applications:
As quoted by Kees,
The N62 of any kind including Alpina versions were NEVER fitted to any E39 or Z8.
The V8S/Z8 roadster engine is based on the single M62tu engine as is the 4.6.
The only Alpina versions of the N62 were the supercharged ones used in the B5/6/7 models.
If you don’t believe me just google pic ‘Alpina V8S engine’
E39 B10 V8/1 #81
E28 B9 3.5 #536
Previously enjoyed
E60 B5 #329
E92 B3 Biturbo #185
Many other BMW's
E28 B9 3.5 #536
Previously enjoyed
E60 B5 #329
E92 B3 Biturbo #185
Many other BMW's
Thats right, the M62tu does have a PAIR or vanos's.B10BRW wrote:This gets interesting I was talking to several B10 V8S owners and 2 Alpina engine Gurus at the meeting in Germany in September .
All were talking about the replacement costs of BOTH vano's on the V8S engine
One for each bank on the inlet side ONLY.
The N62 has Vanos units for both exhaust and inlet on both banks.
I have rebuilt, M60, M62, M62tu and N62 engines in the past.
E39 B10 V8/1 #81
E28 B9 3.5 #536
Previously enjoyed
E60 B5 #329
E92 B3 Biturbo #185
Many other BMW's
E28 B9 3.5 #536
Previously enjoyed
E60 B5 #329
E92 B3 Biturbo #185
Many other BMW's
