Ride Height
Ride Height
Washed car today and it just caught my eye that the rear ride height was different, so measured and drivers side is 5mm lower. Put the car in the garage which I know has a level floor and yes 5mm difference. Not much but bound to be more when driver is in. Thoughts??
B3 1999 (090)
E30 M3 1990
X5 4.6is
VW Mk4 R32
E30 M3 1990
X5 4.6is
VW Mk4 R32
Re: Ride Height
The story goes that this is more a case of the left side being 5mm higher so that when the German driver sits in the car, it levels out...
Re: Ride Height
Is there a solution. Now that I know it will bug me. Can’t believe they sided the springs, can you get different thickness of spring platforms ie the hard rubber bits?
B3 1999 (090)
E30 M3 1990
X5 4.6is
VW Mk4 R32
E30 M3 1990
X5 4.6is
VW Mk4 R32
Re: Ride Height
Never bothered to investigate as I've never noticed an issue with handling - despite my own OCDness.
Re: Ride Height
Just looked up the parts catalogue and indeed you can get an extra 5mm spring seat. Learn something every day.
B3 1999 (090)
E30 M3 1990
X5 4.6is
VW Mk4 R32
E30 M3 1990
X5 4.6is
VW Mk4 R32
Re: Ride Height
Indeed!
Is this just for the OSR spring?
Re: Ride Height
e36's do this also
Re: Ride Height
I may have given some duff info, it appears that the upper pad is listed as "5mm" whilst the lower pad is not listed with a thickness.
B3 1999 (090)
E30 M3 1990
X5 4.6is
VW Mk4 R32
E30 M3 1990
X5 4.6is
VW Mk4 R32
Re: Ride Height
Although I agree with Simon13 as my e30 m3 has different thickness of spring pads.
B3 1999 (090)
E30 M3 1990
X5 4.6is
VW Mk4 R32
E30 M3 1990
X5 4.6is
VW Mk4 R32
Re: Ride Height
My B10 is the same - Just make sure your passenger is heavier than you to balance things up!!
B10 V8 #842
Re: Ride Height
I think from memory the E30's used to have a selection of pad thickness’ available. It was something to do with different specs for different countries
Re: Ride Height
Is this because the fuel tank is on the drivers side?
Re: Ride Height
It was my intention to get the wife to take a measurement with me siting in the car, just to see how much more it dropped, but I forgot and now the car is on axle stands getting the bushes done (nightmare) after 20 years some are rusted to the mounting points. I have a 6 ton press and that won’t shift them. Stripped the threads on the bush removal tool. Replaced the 6 ton jack on the press for a 12 ton and that is working so far but starting to bow the press frame.
B3 1999 (090)
E30 M3 1990
X5 4.6is
VW Mk4 R32
E30 M3 1990
X5 4.6is
VW Mk4 R32
Re: Ride Height
e36s had thicker spring pads, an eastern European roads option on suspension! which was a thicker pad. My old E36 B3 touring used to rub on the rear when giving it shit so I fitted these pads and the problem stopped. Is there nothing listed on realoem for e46s?
Re: Ride Height
Well, the b3 is back on its feet again after being rebushed, I think I’ll have to start eating some more pies, got the wife to measure ride height with me in the seat. A disappointing 1mm drop. Pie eating training starts tomorrow
B3 1999 (090)
E30 M3 1990
X5 4.6is
VW Mk4 R32
E30 M3 1990
X5 4.6is
VW Mk4 R32
