asked Alpina Germany for suspension settings
Hello,
I've contacted Alpina Germany to get the original technical data for my particular car. regarding the suspension settings, I got back data for camber, toe, etc...but tyres are written to be 225/40 R18 (front) and 255/35 R18 (rear). So, can I use the data for a future wheel alignment even if wheels are not the same?
thanks
vincent
thanks
vincent
Simon, IIRC Thomas V8 checked with ALPINA and 19's have different settings to his handbook which only list 18's.Simonal wrote:It should be fine as based on the alignment details for the E39 B10 V8 these are the same regardless of if the wheel are standard 18"s or 19"s
Hope this helps
Simon
Oscar Wilde & Burkard Bovensiepen: I have the simplest tastes. I am always satisfied with the best.
ALPINA B3 3.2 Coupe Switch-Tronic ALPINA Blue
ALPINA B10 3.3 Saloon Manual Mora Metallic
That is interesting because according to Thomas when he posted asking for the setting for a 19" classics I posted my setting from my handbook and Thomas confirmed that they were the same as in his handbook. Have a look at this thread to re-fresh your memory - http://thealpinaregister.com/forums/vie ... highlight=nealpina wrote:Simon, IIRC Thomas V8 checked with ALPINA and 19's have different settings to his handbook which only list 18's.Simonal wrote:It should be fine as based on the alignment details for the E39 B10 V8 these are the same regardless of if the wheel are standard 18"s or 19"s
Hope this helps
Simon
Vincent if you want a definitive answer I suggest you talk to the factory and then they can confirm the settings for you.
V8S Touring
Originally, I've contacted Alpina Germany via the contact form on their website and Elena Disendorf (sales department, Alpina Buchloe) replied and send me the technical data. Who should I contact? factory, how?Simonal wrote:
Thanks,
Vincent
Not sure if he is the right person as I think he is primarily on the sales side of things. But there has been regular mention of a guy called Kris at the factory in Germany and he has always been very helpful.vblanche wrote:Originally, I've contacted Alpina Germany via the contact form on their website and Elena Disendorf (sales department, Alpina Buchloe) replied and send me the technical data. Who should I contact? factory, how?Simonal wrote:
Thanks,
Vincent
Hope that helps a little. You have not stated how current wheels and tyres differ from the originals are they a size down?
V8S Touring
IIRC Thomas made another thread a couple of days later.Simonal wrote:That is interesting because according to Thomas when he posted asking for the setting for a 19" classics I posted my setting from my handbook and Thomas confirmed that they were the same as in his handbook. Have a look at this thread to re-fresh your memory - http://thealpinaregister.com/forums/vie ... highlight=nealpina wrote:Simon, IIRC Thomas V8 checked with ALPINA and 19's have different settings to his handbook which only list 18's.Simonal wrote:It should be fine as based on the alignment details for the E39 B10 V8 these are the same regardless of if the wheel are standard 18"s or 19"s
Hope this helps
Simon
Also Thomas and I confirmed today via text that I was right about the the feedback he had from ALPINA.
- Richy_Boy
- Contact:
I guess that means the ride height is 1/2" higher with 19" wheels...? (Ride height is often part of the alignment checks)
I think it's usually measured from the hub centre to the wheel arch, but those measurements look too big. Maybe ground to arch?
Rich
Rich
Richy_Boy
Current Car: BMW e46 M3 CS SMG
Previous:
BMW 335d M Sport Coupe Highline
BMW 123d M Sport Coupe, no DPF, 275bhp and 520nm of torques.
Historical Alpina B3S Coupe #19 Owner
Previous:
Re: asked Alpina Germany for suspension settings
Hello!vblanche wrote: I've contacted Alpina Germany to get the original technical data for my particular car.
May I ask the e-mail address or something how to contact with them - I need the same data for my B3 3,2 cabrio.
E36 Alpina B3 3,2 cabrio MicaPetrol #27
E15 BMW X5 3,0d white
E01 BMW i3 white
BMW BabyRacer I
BMW sledge M-Tech
E01 BMW i3 white
BMW BabyRacer I
BMW sledge M-Tech
