B3s E91 Tailgate Gas Struts
I believe the BMW part number for these are BMW 51247127875.
Anyone ordered these before, and are they an easy replacement?
Onzie
Onzie
B6 Convertible
B3s Bi-Turbo Tourer
B3s Bi-Turbo Tourer
Re: B3s E91 Tailgate Gas Struts
I believe Ade replaced the ones on his E91
Straightforward to do as a DIY job
B3 3.3 Coupe #090
D3 2.0 Biturbo Touring #098
Onzie - It's a straightforward job but does need strong hands and gloves!
Do one side at a time. Use a screwdriver to lever up the spring clips around the ball joints - remove the bottom (large diameter) first, take care to because the strut will extend as it is removed - they are strong even when old/tired....
Give the ball joint a clean and then installation is simply a case of push fit the top (small diameter) onto its ball and then compress the strut until you get the bottom to fit. - again care is needed along with a dose of muscle.
FWIW - I didn't go for genuine BMW - SGS Engineering do reasonably-priced replacements which are good and seem to last well.
Hope that helps,
Mike
Hope that helps,
Mike
Thanks for the advice Ali and Mike. I'm going to order some this week I think.
I'll post back once I've done them.
Onzie
Onzie
B6 Convertible
B3s Bi-Turbo Tourer
B3s Bi-Turbo Tourer
Use suome wd40 to help you also is easy I did my E90 saloon took 5 minutes per side don't rush take your time. Keep a microfbre with you when you pop of the old strut clean the ball on your boot lid and lubricate it with wd40.
https://youtu.be/pbNZjPYHhtQ
Good luck your will be fine!
2008 E90 Alpina B3 Bi-Turbo (Current)
Previous:
2004 911 997 Carerra 2 Coupe
2009 BMW 740D M-Sport
2007 Mercedes S320 CDI
2005 BMW 730D Sport
2003 BMW 320D Sport
2000 BMW 316i SE
Previous:
2005 BMW 730D Sport
2003 BMW 320D Sport
2000 BMW 316i SE
WD40 has no lubricating qualities whatsoever.
It is an urban myth.
It is great for unseixzing stuck things and to clean things but contains nothing in the way of lubricating materials.
You'll need a teflon based lube like GT85 with PTFE
B3 3.3 Coupe #090
Ordered these last week and fitted them tonight.
It really was a 30 second job on each side
https://www.onlinecarparts.co.uk/stabilus-291198.html
Onzie
Onzie
B6 Convertible
B3s Bi-Turbo Tourer
B3s Bi-Turbo Tourer
